Whats the max?
Old Apr 8, 2009 | 08:23 PM
BretW's Avatar
Vehicle: 2004/Hyundai/Accent
Default Whats the max?
Whats the maxium Hp that an Alpha AT tranny can take before something bad happens? Cause I'm planning on trying to keep up with my friends Honda Accord. Of course I have an AT slowing me down, but I have been able to pull away from some Civics. Any ideas for future mods would be nice. I have cold air intake, exhuast, and a SAFC-2 tuner. plan on going turbo, but want to stay NA right now.
Old Apr 8, 2009 | 08:26 PM
slyderdai's Avatar
What year accord? meh ................doesn't matter. 10lb bottle in the back is the only way you are gonna keep up /win. Beta swap it or boost. But if you have an auto tragic you might as well swap to a 5speed as well.
Old Apr 8, 2009 | 08:29 PM
BretW's Avatar
I tend to forget to tell my year of car lol. Its a 2004, and I'm really thinking a MT swap really bad, but kinda hard finding a donor car in vegas that has all parts I need.
Old Apr 8, 2009 | 08:38 PM
+1 for 10 lb bottle. However, AT does not provide the direct power you would get from a clutch. You loose power in making the fluid spin, which then turns the tranny. MT would be best.
Old Apr 8, 2009 | 08:44 PM
BretW's Avatar
Yeah I figured that. Also isn't an AT heavier than a MT?
Old Apr 9, 2009 | 01:04 AM
The AT is heavier and larger. The AT is supposedly stronger though, with the weak point being the torque converter. If the torque converter is upgraded I've heard that it can hold about 250hp without a problem. I don't think that anyone sells a beefed up torque converter though so you would have to get one custom built. Oh, and you're losing 10%+ more power than through a MT Accent.
Old Apr 9, 2009 | 02:08 AM
jalmir's Avatar
Vehicle: Hyundai Elantra 2000
<div class='quotetop'>QUOTE(187sks @ Apr 9 2009, 03:04 PM) </div><div class='quotemain'>The AT is heavier and larger. The AT is supposedly stronger though, with the weak point being the torque converter. If the torque converter is upgraded I've heard that it can hold about 250hp without a problem. I don't think that anyone sells a beefed up torque converter though so you would have to get one custom built. Oh, and you're losing 10%+ more power than through a MT Accent.</div>
Forget it, the Accent AT are total crap. they can take a beating but need an oil cooler and need more frequent fluid and filter change. Without this, the AT will die pretty fast!
Old Apr 9, 2009 | 07:18 PM
BretW's Avatar
Well I have been calling around vegas and finding out if any transmission shops would do this and some of them were pretty cheap. So I might end swapping it out. Not really worried about smog either, cause I have my sources cool.gif
Old Apr 14, 2009 | 08:56 PM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
They are not made for very much |HP at all.
