What makes a GT/GSi 'sport tuned'?
Old Nov 9, 2009 | 10:25 AM
no_name's Avatar
Vehicle: 2005 Accent GSI
Default What makes a GT/GSi 'sport tuned'?
So I've got a 2005 Accent GSi (GT) and I know it's marketed as having 'sport tuned suspension' but I have no idea what that means. Does anyone know what's sporty about it? Different spring rates? Stiffer dampers? Is there some special consideration if I upgrade the suspension? Would GT suspension be a cheap & easy upgrade for a regular Accent?
Also, GSi sounds way lamer than GT. Does anyone know where I could get a GT logo to replace my GSi?
Old Nov 9, 2009 | 10:49 AM
ereeves116's Avatar
Vehicle: 2002 Accent
look through out these pages
http://kspec.com/main.php?ac_id=33&s=&pg=7
and i think you'll be able to find pretty cheap suspension. I would not suggest "gt" suspension as an upgrade, i highly doubt it's that much nicer, especially back in the day.
Old Nov 9, 2009 | 01:18 PM
For the 03-05 Accents anyways there is a significant difference. The car rides about half an inch lower than regular Accents and has significantly higher spring rates. I don't know if the dampening is better or not, but having driven enough of both I don't think the dampening is any different. I think the only difference is the spring rates.
The GT springs are a lot like the Eibach springs in their stiffness. I don't think either is a valid way to improve performance. The GT springs are superior to regular Accent springs, but a good set of stiffer springs will do a lot more than switching to GT springs would.
Old Nov 9, 2009 | 04:44 PM
racecar13's Avatar
Vehicle: 2002 hyundai accent
if you go to the suspension specs on alldata it sais there about a 1/2 inch shorter.
like 187sks said unless there free just save up for aftermarket springs
Old Nov 10, 2009 | 08:55 AM
no_name's Avatar
Thanks. I wanted to make sure that switching to different springs would still be worth it. I'm considering Eibachs. So if the GT is already 1/2" lower, I'm assuming I'd only get 1" further drop out of the lowering springs?
I also just remembered, I read somewhere that the GT springs were progressive while the stock springs were linear.
Old Nov 10, 2009 | 11:17 AM
I doubt that you'll get an additional half inch of drop from the Eibachs, and maybe 10% more stiffness vs the GT. The Eiback springs are crap IMO, too soft.
I'll look at my springs today and see if they're progressive.
Old Nov 11, 2009 | 08:49 AM
no_name's Avatar
So then what springs would you recommend? I want to drop the ride height a bit, but mostly increase the stiffness and reduce body roll. I plan on getting a rear sway and some new OEM replacement shocks while I'm at it, either GR-2s or ACDelco Premiums.
Old Nov 11, 2009 | 04:36 PM
Checked and my springs are not progressive.
I would suggest Whiteline Flatout springs with a set of Koni yellow strut inserts. Unfortunately the Whiteline Flatout springs have been discontinued and if I find a set I'll be buying them.
Short of them, I would go with some H&R springs. If you don't want to pay for the Koni's, KYB GR-2 struts perform slightly better than stock, especially with the sport front struts which have slightly stiffer dampening than the non-sport GR-2 struts have.
Best GR-2 part numbers:
FP W0133-1615967
FD W0133-1615785
RP W0133-1616359
RD W0133-1616505
Koni inserts for 49mm struts:
F 8610-1411 sport
R 86-2632 sport
Koni inserts for 45mm struts:
F 86-2551
R 86-2552
Old Nov 12, 2009 | 10:02 AM
no_name's Avatar
Ya, I looked at the Konis but they're way out of my price range. GR-2 it is then. Those H&Rs aren't cheap though. I've found someone selling a set for the 94-98 Accent. Any chance those will fit on an LC?
And the GR-2s are listed as 'with ABS' does it matter if I dont have ABS?
Old Nov 12, 2009 | 07:06 PM
I have personally installed the w/ABS GR-2's on a non-ABS car with no issues. I think it just has an extra spot to attach a bracket. No problem at all.
The 94-98 springs will work but they're probably too low of a spring rate. Not enough to cause problems, but enough to negate the advantages of the H&R springs vs. other Accent lowering springs.
