Tib Throttle body on Accent
Old Dec 17, 2002 | 12:35 PM
Juan Jose's Avatar
Default Tib Throttle body on Accent
Hello
Is it possible to modify a 2.0L Tiburo Throttle Body with cruise control to fit a 1997 1.5L soch Accent?
Thanks.
And what is exacly needed to make it fit if so?
Old Dec 19, 2002 | 02:02 AM
Al's Avatar
Al
yes it has been done...i cant remember by who...Grundelman i think
all i know is that TB need to be re-drilled to match with holes on IM
hope that helped any
Old Dec 19, 2002 | 03:16 AM
Ace_Cobra's Avatar
you will need to do 4 new holes in the tb to fit the
accent intake manifold!
after that its bolt on!
Old Dec 19, 2002 | 11:57 AM
Juan Jose's Avatar
hey
what way is better
holes on the manifold?
or holes in the throttle itself?
how wide is the throttle on the 2.0 TIB?
thanks
Old Dec 19, 2002 | 12:00 PM
Ace_Cobra's Avatar
why do you want to hole the tb?
Old Dec 19, 2002 | 01:40 PM
DynastyAccent's Avatar
Hey, I want to do this soon, so I just wanted to make sure that a TB off of a 2001 Tib will fit my 98 Accents. Thanks.
Old Dec 19, 2002 | 07:39 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
Holes on the TB. In case you might want to revert back to the old TB it would be better.
Old Dec 22, 2002 | 12:20 PM
evoaccent's Avatar
Like Al said, i have put a 2.0L tibby tb on my x3.
Here was the process.....The 1.5L has a lil hole inside of the tb thats used as the idle air bypass. The tiburon's TB doesnt have this hole. So, I went and bought a breather filter to connect in place of the third hose. I then redrilled the bolts and enlarged them so that it would sit flush with the im. I then bolted it down and saw that the stock rubber hoses was to small and wouldnt fit over the tb, so I went and bought a replacement hose from autozone off there civic intake(the blue connector hose). I placed it over the tb and then connected to my stock 2" hoses. Right now it runs great! But, sometime in the near future, I would like to go and get the stock tiburon hose and connect it to the tb, so it will look more clean.
Old Dec 23, 2002 | 03:22 PM
Z3R0's Avatar
you guys may wanna try useing a throttle body from a scoupe its a direct bolt on all you have to do is cap off some of the hose openings that you don't use from the scoupe (im in the middle of preppin for it right now)
