sway bars?
Old Jul 18, 2011 | 08:51 AM
juliogonza's Avatar
Vehicle: accent
Default sway bars?
hi this is my fisrt topic... weeeeeeeeeeee.....
now i am just asking about some feed back about this sway bars Iused to buy some stuff for my ex tercel for whiteline and they was the best thing on my cheap car... now I buyed a 2004 accent and i am searching about this bars and the only one i found is the rear of whiteline but i dont know who sell them... and searching i found the UR sway bar and i was thinking if someone haved buyed them to give me some feedback about this sway bar... or if someone in USA sell the whiteline sway bar... thanks
Old Jul 19, 2011 | 06:53 AM
no_name's Avatar
Vehicle: 2005 Accent GSI
Whiteline stopped making sway bars for the accent a few years ago. I tried last year to find one and any web site that had them listed told me that their supplier was actually all out. So I bought one from UltraRacing. When I bought it they had also stopped making them but 5 months later they started again and now I have the bar. You should contact them before you order to make sure they can get it (the factory is in Malasia).
It's a good quality 19mm bar but at about $300 after shipping it's pricy. It comes with new rubber bushings so you may want to order a 19mm polyurethane sway bar busting kit from Energy Suspension (eBay). It will help. But make sure you use the provided grease or it will SQEEK
You also need to buy new sway bar end links. They're not meant to be removed and are very likely to snap when you're removing them. I had the use a massive breaker bar to get them off and the nut didn't rotate, the end the bolt did, on both sides. Including the endlinks and bushings it cost closer to $400.
Old Jul 19, 2011 | 09:58 AM
juliogonza's Avatar
Vehicle: accent
a little spensive but i think i am going for it.... i would buy the bushings in polyurethane because i need some alignement.... and the sway bars i should buy them later... if the next gen seller tell me a good prize for the rear bar i shoulb buy them first than the bushings...
