REmoving flywheel from accent tranny
Old Feb 7, 2009 | 03:51 PM
Fintile's Avatar
Default REmoving flywheel from accent tranny
Hey guys I just need to know the tool and what size is needed to remove the bolts from the flywheel of an Accent tranny. I assume its the same for all years?
Old Feb 8, 2009 | 11:45 AM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
It should be a 17mm socket, you will need an impact wrench. They should be on their with 100 ft lbs of tq, or somewhere in the ballpark. If you need help removing it give me a shout, done it a couple of times.
