Removing cat ?
Old Aug 31, 2001 | 01:36 PM
Accent GSi's Avatar
Default Removing cat ?
Just wondering if I remove my cat, which one should I remove ? I have a 2k accent. The one in the middle of the car or the one at the headers ??? I'm looking for sound and a bit of hp (ha ! if its possible tongue.gif)
Old Aug 31, 2001 | 05:38 PM
it is against USA Federal Law to remove or even relocate a functional cat converter. Check within canada to see what your laws are.
But if you WERE to install a set of headers...the up front unit would have to go, and that would give you the best HP gains.
Old Aug 31, 2001 | 10:48 PM
2K3GT/2K Wagon's Avatar
My suggestion would be, if you were to remove the front cat, to buy another manifold/cat and remove the cat from that one so that you could easily replace yours if you had to. I save all my original parts.
Old Aug 31, 2001 | 10:55 PM
Accent GSi's Avatar
Sorry, I was wrong, I was thinking about the resonator, my friend just laughed his head off cause I called it a Cat. Is there going to be a gain of HP if I remove the Resonator ?? If any ?
Old Sep 1, 2001 | 04:11 AM
I'm not sure on the accents, but on the Tiburons, the resonator is also a restrictor, and a pretty bad one. It drops the pipe diameter from 2" down to 1.5" inside the resonator. This provides backpressure for the engine.
If you remove this, you will probably loose low end torque, but you should gain top end power. I would only reccomend doing this on a 5-speed, and the autotragic needs the low end power.
Old Sep 1, 2001 | 09:05 AM
Accent GSi's Avatar
well it's off and the car sounded like crap ! So I put a glasspack(cherry bomb) at the place of it and it's a better. The sound changed a TINY bit. Without it sounded like a damn Pony !hehehe
