breather filter question and intake question
Old Sep 1, 2001 | 10:10 AM
erikgsi's Avatar
Default breather filter question and intake question
ok random. yes i go right for random hehe.
i am going to make a new intake for my accent im sick of my old cai. well i wantt o eliminate that hose going from that funny looking thing into the intake. someone told me that i could put a breather filter on that thing and i wouldnt have to cut a hole into my pipe. is this true? or are there any other ways to get around having to put a hole into my pipe for that tube. by the way what exactly is that tube? thanks if anyone else knows anything about this please reply
thank you
[ September 01, 2001: Message edited by: erikgsi ]
Old Sep 1, 2001 | 03:25 PM
I'd have to see a photo of the accent motor to know exactly what you are talking about, but I think I have a pretty good idea.
There are 2 hoses the exit the top of the valve cover. One is the PCV (Positive Crankcase Ventilation) valve, the other is the breather hose.
The PCV valve hose routes directly to the intake manifold. The breather hose routes to the intake, before the throttle body.
You COULD put a breather filter on the end of the breather hose...however, at low RPM, that breather hose belches out a mixture of air and oil. That oil accumulates in your breather filter and can drip out inside your engine. At high RPM the breather hose sucks IN air. You cannot just block it off, so you have to vent it somewhere.
Summit Racing makes breather catch tanks. They are about $30, and come in a variety of colors. They are just a plastic tank with a petcock on the bottom for draining the accumulated fluid, with a breather element on top. I would reccomend one of these if you want to move the breather hose.
DO NOT re-route/disconnect the PCV hose.
Old Sep 1, 2001 | 05:21 PM
erikgsi's Avatar
thanks random. i was thinking about getting the breather filter that apc makes. its called intimidator. i wasnt real sure of the quality of apc though.
thanks again ill look into it.
