Performance cams
Old Jul 11, 2008 | 10:49 AM
minorglitch215's Avatar
Vehicle: 2002 hyundai accent
Default Performance cams
Intake/Exhaust Camshaft Pair, 274 Degree Duration
by Hwarang Performance Products
HP.Com Price: $680.00 ea
Item Number: HWA CSA274PA
Shipping Weight: 5 lbs.
Dimensions: 7" x 3.5" x 20"
Ships in 21 days
Customer Rating: Not yet rated
Stock ECU & Cam Gear
00-02 Accent 1.5L (LC)
95-97 Accent 1.5L (X3)
93-95 S-Coupe 1.5L (non turbo) (Series II)
91-92 S-Coupe 1.5L (Series I)
www.fasthyundai.com
any thoughts? is this bogus?
Old Jul 11, 2008 | 11:54 AM
Hwarang has been making Hyundai cams for a long time so I would say it's not bogus.
Old Jul 11, 2008 | 10:24 PM
<div class='quotetop'>QUOTE(187sks @ Jul 11 2008, 12:54 PM) </div><div class='quotemain'>Hwarang has been making Hyundai cams for a long time so I would say it's not bogus.</div>
newbish question. would this fit my car. It looks like it goes to a DOHC, which mine is not.
Old Jul 11, 2008 | 10:40 PM
It'll fit the SOHC 1.5l.
Old Jul 11, 2008 | 10:52 PM
<div class='quotetop'>QUOTE(187sks @ Jul 11 2008, 11:40 PM) </div><div class='quotemain'>It'll fit the SOHC 1.5l.</div>
i am mere peanuts to your vast amounts of automobile-knowledge 187, so i ask, how will it work?
Old Jul 12, 2008 | 02:20 AM
Lol, I assure you I'm no expert but thanks for the compliment.
What do you mean how will it work? How will it install, how will it run, how will it make power compared to stock, or what would you like to know?
Old Jul 12, 2008 | 02:37 AM
<div class='quotetop'>QUOTE(187sks @ Jul 12 2008, 03:20 AM) </div><div class='quotemain'>Lol, I assure you I'm no expert but thanks for the compliment.
What do you mean how will it work? How will it install, how will it run, how will it make power compared to stock, or what would you like to know?</div>
pretty much all of the above.
The description says intake/exhaust pair, 2 camshafts... to my understanding my SOHC uses one cam to regulate the intake and exhaust valves... i'm very hesitant to purchase pricey things unless i know exactly what im getting, is what im looking for.
Using HMAservice and logical mechanical thinking ill be able to intsall it when it comes.
Old Jul 12, 2008 | 11:39 AM
Well, it's only for one cam in your application. I would get a hold of the customer service at fasthyundai before paying to make sure they really have a cam for you. The application list is plainly for the SOHC 1.5l though, the Scoupe never came with a DOHC Alpha for one thing. It's not really clear but I suggest you contact them.
It'll make more power by increasing valve lift and duration allowing for more A/F mix to be drawn into the cylinders and more exhaust to be expelled. Depending on how aggressive the cam is vs. stock it may make your car idle rough and your ECU may have trouble controlling your engine if it's too far from stock. I would ask them also how well the stock ECU will run with this cam. Cam installs aren't that bad if you follow procedure and make sure that you mark everything so that you're not a tooth off (or more) on the timing belt.
Old Jul 12, 2008 | 09:49 PM
Fintile's Avatar
see this goes right back to that question I had. Now it does state its for the 1.5, but what about the 1.6?
Old Sep 16, 2008 | 05:13 PM
Jeremy's Avatar
Vehicle: 02 Hyundai Accent GS
any when get any futher on this?
