oil lines
Old Jan 25, 2012 | 01:28 PM
WRC_Accent's Avatar
Vehicle: 2000 Accent
Default oil lines
Hi all,
I an installing a Turbo onto my Accent. The turbo has coolant and oil fittings. Coolant, no problem, just going to tap into the cooling system somewhere between the water pump and the radiator. not a problem. Oil lines... return line is easy. Just add a fitting the side of the oil pan. Oil supply... thats the problem. Where do I get oil from? Pics are always helpful.
Old Jan 26, 2012 | 02:03 AM
Red Raspberry's Avatar
Get an oil filter adapter that has some ports on it. Usually for a gage sender. The ones for Honda work with the Hyundai filter..
