Need help on beta swap
Old Sep 28, 2009 | 06:54 PM
patdeman's Avatar
Vehicle: 2000 hyundai accent GS 1.5L
Default Need help on beta swap
Im preparing to do the beta swap, but the thing is that i just bought a new clutch for my accent 1.5L and would want to keep it in for the swap (i'l be using the 1.5L accent trans) and i heard the clutch wont fit on the elantra flywheel, but can i mount my accent flywheel onto the elantra engine ?
any answer would be greatly appreciated.
Old Sep 28, 2009 | 08:59 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
Nope, if i remember the accent is a 5 bolt and the beta is a 6 bolt. I just know it will not fit. You might want to think about returning the clutch if unused.
Old Sep 29, 2009 | 01:53 PM
patdeman's Avatar
cant, its been on my accent for about 2-3 weeks but now another question, if im going NA, will a stock scoupe turbo clutch be good enough ?
Old Sep 29, 2009 | 03:02 PM
Thats what im using. Not issues so far.
Old Oct 2, 2009 | 10:01 AM
342Four's Avatar
Vehicle: '97 X3
yup
215mm scoupe turbo clutch mates to the flywheel
tbh if you want to get tricky get a getz/click gearbox and put the x3 accent 2nd gear in - that way you'll get a higher ratio for 1st, a lower 5th and a final drive of 4.1 ish
failing that just use a MC gearbox
fyi:
M5AF3 X3 Excel: 3.462, 2.053, 1.37, 1.031, 0.838 Final Drive = 3.842
Getz 1300: 3.615, 1.95, 1.37, 1.061, 0.825 FD = 4.056
putting the 2nd gear in makes it:
3.615, 2.053, 1.37, 1.061, 0.825, 4.065 FD
