Low end torque
Old Jul 21, 2011 | 10:06 AM
g4ebguy's Avatar
Vehicle: 2002/Hyundai/accent 1.5L sohc
I disagree with PAS, If low end torque is what your after a intake and header, full exhaust could actually hurt low end torque but increase top end *near redline*
If you really want more low end, a very small turbo t-15- to t-20 size would be what you want and a low intercooled 5 psi.
Old Jul 21, 2011 | 11:23 AM
Tuning is the key. Header tubes can be tuned for greatest efficiency at a single engine speed and greater efficiency at a certain engine speed range. Headers can be tuned for increased torque down low, increased power at the top end . . . but you don't get to choose unless you design your own headers.
If you DO get an exhaust, chances are your butt-dyno will tell you something good, and you will be happy even if you did lose a couple of % at very low engine speeds.
Old Jul 21, 2011 | 12:13 PM
g4ebguy's Avatar
were still talking like a 1-5% difference here. not even worth caring about.
Old Jul 21, 2011 | 02:32 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
doing some weight reduction could help with the feel of the car-... and it's free!
did anybody mention the coolant bypass?
Old Jul 22, 2011 | 01:44 AM
I/H/E with 4-2-1 headers netted me 100whp and 109lb/ft of torque at 2200rpm's. My car was rated at 104hp and 106lb/ft at the crank stock. I would call that a nice bump in low end torque. That's something like 128lb/ft at the crank.
Old Jul 22, 2011 | 12:29 PM
<-- wonders if you saw a similar bump in fuel economy
Old Jul 24, 2011 | 03:24 AM
Yep, a nice bump in fuel economy, about the same percentage probably.
Old Jul 25, 2011 | 01:15 PM
no_name's Avatar
Vehicle: 2005 Accent GSI
What parts did you use for the intake and headers? Was the exhaust custom? 20 HP increase + better fuel economy sounds very enticing.
Old Jul 25, 2011 | 03:47 PM
Intake: ebay special 3" diameter short ram with a K&N filter
Header: Evofusion 4-2-1
Exhaust: custom 2.25" crush bent
Old Jul 27, 2011 | 07:19 PM
koreancorvette01's Avatar
Cam gear. On our cars the external gear acts as if we are a sohc . Which basically will move your powerband into a lower rpm . With a good short ram intake it could get a little better. Honestly ......supercharger is the way to true low end torque from the get go.
