Coil over sleeves
Old Feb 27, 2012 | 12:13 PM
gideon's Avatar
Vehicle: 01 Accent
Default Coil over sleeves
How beyond crappy would my car handle if I tossed coil over sleeves on it (not real coil overs), but swapped out the springs with quality ones like Eibach or H&R? They would be partnered with good shocks obviously like KYB.
Old Feb 27, 2012 | 12:25 PM
no_name's Avatar
Vehicle: 2005 Accent GSI
I've tried to track down 'good shocks' for the LC Accent. Koni has sadly stopped making the Yellows for this car. What do you plan on using? I already have H&R springs and dont want to install them until I have better shocks.
Old Feb 27, 2012 | 05:23 PM
I'd look for someone with old stock of the Koni yellows, or make other inserts work. Someone years ago welded threaded strut tops from an AE-86 onto his Accent struts and used AE-86 replacement cartridges.
Old Feb 27, 2012 | 06:36 PM
no_name's Avatar
Using AE86 parts is not a bad idea, plentiful and cheap with similar weight, however very different weight distribution. Actually my Accent handles very similarly to my old 86, one of the reason I like it so much.
