Canadian MC Accent 1 of 500 SR Models, Very Modified!
Old Jun 23, 2008 | 10:44 PM
Komptek's Avatar
Vehicle: 2007 Accent SR
Default Canadian MC Accent 1 of 500 SR Models, Very Modified!
Just thought I'd post the link here to my ride. It's a very modified SR Model Accent and is still being modified to the point of getting a turbo installed which is on order now.
Visit My Accent SR Website
Old Jun 24, 2008 | 09:32 PM
J0eFr0's Avatar
Vehicle: 2000 Hyundai Accident
very clean i like it, can't say i'm a fan of the new accent, but i like yours smile.gif i'd rock it
Old Jun 25, 2008 | 12:39 AM
Fintile's Avatar
hey, any way of knowing if that engine damper would fit the 04 models?
Old Jun 25, 2008 | 02:31 AM
Komptek's Avatar
<div class='quotetop'>QUOTE(J0eFr0 @ Jun 24 2008, 09:32 PM) </div><div class='quotemain'>very clean i like it, can't say i'm a fan of the new accent, but i like yours smile.gif i'd rock it</div>
No Ideal but I guss you could ask the guys at KFX
Old Jun 25, 2008 | 04:53 PM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
That thing looks mean.
Old Jun 26, 2008 | 12:00 AM
Komptek's Avatar
<div class='quotetop'>QUOTE(Whiplash @ Jun 25 2008, 04:53 PM) </div><div class='quotemain'>That thing looks mean.</div>
It will be mean once the TUrbo in installed. 200+ HP
Old Jun 26, 2008 | 01:39 PM
You doing anything to the internals to hold up to doubling the power?
What are you doing for engine management?
Old Jun 26, 2008 | 01:45 PM
Komptek's Avatar
<div class='quotetop'>QUOTE(187sks @ Jun 26 2008, 01:39 PM) </div><div class='quotemain'>You doing anything to the internals to hold up to doubling the power?
What are you doing for engine management?</div>
As for upgrades internals pretty much just larger Injectors, 2.5Bar MAP sensor, and NGK high heat sparklugs. is all that is needed. As for management I'll be using a Unichip Piggy back system.
Old Jun 27, 2008 | 05:05 AM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
If your gong 200+ ponies, I would at least think of getting some of your internals worked on. I'm unsure of what the stock HP is, but if its the 1.6 it should be around 120-130. If you’re going to try for 200+ you’re going to blow something up with out internals. That’s just my $0.02 on that. I have done some research on this when i was going to turbo my 1.5.
How much PSI are you planning to run to get to 200+.
Old Jun 27, 2008 | 08:14 AM
That's going to require 10psi to hit 200hp at the crank.
