Accent TBI
Old Oct 22, 2002 | 10:34 AM
mohead's Avatar
Vehicle: 2K Accent
Default Accent TBI
Has anybody put a Tib TBI on their Accent? If so, what should I know about the install before I try. Any info would be appreciated.
Old Oct 22, 2002 | 11:46 PM
Brendan's Avatar
The tib throttle body won't fit the accent, well it may fit but the cables are all wrong. I would get a used accent TB and bore it out, also port the intake manifold to match, 55mm I think is good.
Old Oct 23, 2002 | 12:13 AM
stickshift's Avatar
Vehicle: 2000 Tiburon
I thought it did work, and all that was needed was to drill new holes in the new TB to match up with the Accent's IM?
Old Oct 23, 2002 | 02:23 AM
Brendan's Avatar
there is no room to really drill new holes ( you risk drilling the existing ones to large ), plus the cables are still wrong, your still better off getting a BTB made for the accent, and they are out there.
Old Oct 23, 2002 | 01:47 PM
mohead's Avatar
Vehicle: 2K Accent
Thanks for the info. I found out on the SS Tour to NOPI about my car. One, I need better brakes and two I need MORE power. Thanks again Robert
Old Oct 23, 2002 | 01:51 PM
Ace_Cobra's Avatar
i've a Tib TB on my 1.5l accent you need ton slot the hole
thats a previeu after my installation wink
(before the clean up)
http://www.cobraspeed.net/ace/images/TBetbreather.jpg
after
http://www.cobraspeed.net/ace/images/05200...02/IMG00020.jpg
Old Oct 23, 2002 | 10:14 PM
Ace_Cobra's Avatar
you also need to put the Accent TPS, dont use the TIburon TPS wink
Old Oct 23, 2002 | 11:43 PM
Brendan's Avatar
Cobra how did you get around the cables?
Old Oct 24, 2002 | 12:49 PM
Ace_Cobra's Avatar
the gaz wire fit on the Tib TB wink
Old Oct 25, 2002 | 08:17 AM
accent 1's Avatar
I have the elantra TB on my accent! I just drilled new holes in the new TB and then modified my Throttle cable bracket( I had to space it out about an inch) and mine works great!
The tib and the elantra share the same TB I also use the elantra TPS on mine and have had no problems with it!
A great up grade for the price!
I have the 97 accent 1.5 12 valve just to set the record straight!!!
