accent nitrous ?'s
Old Aug 18, 2002 | 12:49 AM
rubenz2K1's Avatar
Default accent nitrous ?'s
hey guys i would like to know what kinda limitations i have with nitrous on my stock accent.
i know that the accent can handle a 60 shot of dry nitrous. So what can it handle with a wet shot? also what can it handle with direct port nitrous system? also what would i neeed for a fail safe setup?
the reason i need to know is cause i guy at work has a friend that sells him stuff at wholesale and i need to know what kinda system i would want/need so that i can get a price. thanks.
[ August 18, 2002, 07:50 AM: Message edited by: ruben-z's 2K1 ]
Old Aug 18, 2002 | 06:53 AM
QS's Avatar
QS
Wet is safer, an on stock internals dont go more than 55.
I suggest using the NX kit.35-50-70
Old Aug 18, 2002 | 11:51 AM
rubenz2K1's Avatar
do you know if the nitrous limit is 55 on all styles of nitrous (direct port, wet,dry,etc.)
Old Aug 19, 2002 | 12:32 PM
rubenz2K1's Avatar
anybody else got info.
Old Aug 19, 2002 | 12:43 PM
xHATEx's Avatar
you are aware that you have no return fuel line, correct?
Old Aug 19, 2002 | 12:45 PM
rubenz2K1's Avatar
nope. and what does it mean i can't do.
Old Aug 19, 2002 | 09:13 PM
Spatch359's Avatar
I means that you can't use a kit like Zex. I would use the NX import kit or a Venom kit and run about a 50 shot.
Spatch!
Old Aug 19, 2002 | 11:32 PM
rubenz2K1's Avatar
so can i run direct port. eek!
Old Aug 20, 2002 | 01:00 AM
Spatch359's Avatar
I don't see why not as long as you go with a 50 shot and no higher. The direct port kit just cost more. The NX kit actually pumbs into your existing fuel lines so that it doesn't have to have a return fuel system. Just remember nothing over 50 until you get a larger fuel pump. smile.gif The NX kit mixes fuel with the nitrous and that adds a few extra horse power to the 50 already being applied.
Spatch!
Old Aug 20, 2002 | 01:09 AM
rubenz2K1's Avatar
well accents have been running a 60 dry shot with no problems. shouldn't i be able to go with a higher shot of direct port.
