Accent 1.5 2002 vs BETA 2 alternator
Old Feb 10, 2010 | 09:26 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
Default Accent 1.5 2002 vs BETA 2 alternator
Are their any differences between these two alternators? ex... wiring, mounting...
Old Feb 10, 2010 | 10:34 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
<div class='quotetop'>QUOTE (jsharptooth91 @ Feb 11 2010, 04:26 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Are their any differences between these two alternators? ex... wiring, mounting...</div>
I know ryan is running an alpha alternator on his beta accent. I think he had to shim it a little, but it works fine.
Old Feb 10, 2010 | 11:11 PM
<div class='quotetop'>QUOTE (WytchDctr @ Feb 10 2010, 09:34 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I know ryan is running an alpha alternator on his beta accent. I think he had to shim it a little, but it works fine.</div>
I am also running a alpha alt on my beta motor. My alt is going out and I believe that the beta runs more amps. I was just wondering if it was a 1 for 1 swap?
Old Feb 10, 2010 | 11:19 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
If I can find the accent alternator I have, Ill compare it to the alt on my elantra.
Old Feb 10, 2010 | 11:53 PM
ereeves116's Avatar
i went with the beta alternator only because it was already attached and i didn't exactly want to have to worry about getting the alpha alt on there.
Old Feb 11, 2010 | 10:02 AM
<div class='quotetop'>QUOTE (ereeves116 @ Feb 10 2010, 10:53 PM) <{POST_SNAPBACK}></div><div class='quotemain'>i went with the beta alternator only because it was already attached and i didn't exactly want to have to worry about getting the alpha alt on there.</div>
So it sounds like the beta and alpha share the same connections.
When I installed my alpha alt on my beta motor, is was pnp. No special anything, it installed like it was made for it.
Anyone know if the beta alt has more amp than the alpha?
Old Feb 11, 2010 | 10:27 AM
I think they're both 90amp, but some LC's had 80 amp.
