1.5 DOHC or 1.6 DOHC ?
Old Jan 16, 2002 | 12:20 PM
duclos's Avatar
Default 1.5 DOHC or 1.6 DOHC ?
I`ve been hearing all kind of controversy about the difference between these 2 engines. I have the 1.5 DOHC. Beside the longer stoke on the 1.6, what are the differences? Which one is better? What is the 0-60 time for both stock cars?
Thanks
Old Jan 16, 2002 | 12:40 PM
This forum is for general Team SR member related questions only.
Old Jan 16, 2002 | 01:32 PM
JP's Avatar
JP
Vehicle: 1998 Accent
The 1.6L has only 1 hp gain over the 1.5L, but there is a significant bump in torque, and it comes in much lower in the rpm range. I believe the bore is different as well as the stroke. 0-60 times are kinda useless since you are talking about a larger, heavier Accent. If you really want to know, there is a website that has 0-60 times for almost every production car around. I can't remember the website off hand.
Did you buy a different car? Your sig says '93 Excel - that is a different motor altogether, and only SOHC 8-valve 1.5l.
[ January 16, 2002: Message edited by: JP ]
Old Jan 16, 2002 | 11:10 PM
duclos's Avatar
I sold the Excel. it was is pretty in good shape but I got a 97 Accent GT whit 40 miles for 4 500can (half of the listed price). It was about to be repossed the day after. I coundn`t refuse the deal.
Old Jan 18, 2002 | 02:54 PM
skierd's Avatar
Vehicle: 1997 accent L
The bore of the 1.6L is slightly more. Also, the block is stronger (supposively), the intake cam has more lift, and its equipted with a MAP sensor. There;s a good article on the 1.6L over on hyundaiperformance.com.
Other than what i posted, i think they are basically the same motor.
[ January 18, 2002: Message edited by: skierd ]
