URGENT AS ALL HELL
The fluid the the Clucth actuator assembly is brake fluid. It should be clear when new, and brown when old. If brown, flush and replace.
The Gear oil IN the manual tranny should be clear/slightly brown when new, and should stay that way...if it's brown...change it.
If you have some liquid sprayed up the engine side of your firewall....it's NOT good.
The obvious was not stated, so I'll throw it in there. Check all the fluids. Check all the hoses. Look for cracks, leaks or drips. Start the car...look for leaks that only happen when the car is running.
If it shakes when first put into motion...that sounds like something in the tranny, or something to do with one of the drive halfshafts.
It sounds like you tried to "bump" start it and damaged the transmission.
Did you guys try to "bump" start the car by someone pushing it, then poping the clutch?
Originally posted by KamikazeePilot:
nope..... jumper cables. I took it to the shop, it was my axel and flywheel.... need new of both, yum yum!!
If you car was just sitting there...with the lights on. How did the axle and flywheel get damaged???????? eek.gif eek.gif
