OD light backwards
Old Oct 25, 2001 | 08:55 AM
cringe's Avatar
Default OD light backwards
I get the "O/D Off" light when overdrive is on, and it goes off when I turn O/D off. Is there anyway I can switch it, or just disable it without having to get under the dash?
Old Oct 25, 2001 | 12:49 PM
Iago's Avatar
There's always the "electical tape" method.
1) Cut out a square of electical tape approximately 1/3" square.
2) Apply tape over light of annoyance.
3) Fuhgedaboudit.
Old Oct 25, 2001 | 01:14 PM
cringe's Avatar
that is so lame.
please notice the thumbs down icon.
I suppose I'll just go back to stock if I can't figure something out. The problem is the new shifter has a ground and a hot wire, the tib has three, one for the tranny, one for the light, and a ground. I've tried every combination and backwards is as close as I can get.
[ October 25, 2001: Message edited by: cringe ]
Old Oct 25, 2001 | 02:53 PM
Iago's Avatar
Oh come on! It was at least MARGINALLY funny... You gotta admit that.
Old Oct 25, 2001 | 02:56 PM
ICE3X's Avatar
i thought it was funny
Old Oct 26, 2001 | 01:13 AM
DESIGN's Avatar
The overdrive button is simply a switch right? Maybe its hooked up in reverse. It has to be something to do with the switch.
Old Oct 26, 2001 | 01:16 AM
cringe's Avatar
I know exactly what is causing it. The light wire is connected to the ground for the shifter, since my new shifter only has two wires and the tibby has three. The only way for the overdrive and light to work was to hook it up so that the "OD off" light is lit when overdrive is on.
Old Oct 26, 2001 | 01:55 AM
Gimme the weekend to dig through the manual and find out what the three wires do.
There should me a way to make it work.
Old Oct 26, 2001 | 01:59 AM
cringe's Avatar
You the man!
Old Oct 26, 2001 | 02:34 AM
Iago's Avatar
I looked at the directions for a different automatic shift knob that also only has two wires. They didn't give a direct solution; they just said to leave the O/D wire disconnected. rolleyes.gif
Probably not the solution you're looking for, but it is an option, if all else fails.
