need help with mass air flow for cold air intake
Old Aug 24, 2002 | 05:36 AM
sage's Avatar
Vehicle: 2001 Accent
Default need help with mass air flow for cold air intake
I just picked up everything i need for a cold air intake for my 95 elantra, but ran into some problems when i realized my mass air flow sensor inside the old air filter box was huge. Does anyone know a way i can either get a smaller air flow sensor to fit inside my intake tube or inside the cold air filter. Any info would be appreciated. Thanks Sage.
Old Aug 24, 2002 | 01:13 PM
Al's Avatar
Al
ummm i always thought that the sensor in teh air box was teh temp sensor, it may be different in Alphas tho....anyway i am 100% you can not get different air sensor
Old Aug 24, 2002 | 01:29 PM
Denisst99's Avatar
look at DSM..
get an adaptor that will adapt your MAF to a good air filter and just configure your piping to place the MAF/air filter assembly in a good cold spot
Denis
Old Aug 26, 2002 | 01:37 PM
sage's Avatar
funny thing is that the mass air flow sensor for this particular engine is to big to fit into the pipe or filter. The stock air filter is one of the oval kind and the sensor takes up the entire hollow of the original filter. Its kind of hard for me to explain b/c ive never seen one like it before in any other model of car.
Old Aug 27, 2002 | 11:59 AM
accent 1's Avatar
http://groups.msn.com/TeamsrGA/accent1pict...oto&PhotoID=202
try this link you can see a layout of an intake that I built it may help you out!
Old Aug 27, 2002 | 01:27 PM
Denisst99's Avatar
Sage, you have the exact same set-up used on eagle talon/mitsu eclipse....
just look for an adaptor and air filter for those cars,.. Injen, Ractive... they all have what you wil lneed to make yourself a CAI
Here's what your layout should look like...
T.B. rubber coupling,metal tube,rubber coupling,MAF,air filter adaptor,air filter
Denis
