Could it be the Starter?
Old Sep 21, 2002 | 02:05 AM
IX_XI's Avatar
Vehicle: 2001 Tiburon
Default Could it be the Starter?
BACKGROUND INFO:: This has happened a couple of times now. It will do it @ various times during the day. I have to start the car @ least 20X a day. It can do it first thing in the morning, or whenever.
Turn the key to start the car, car starts, but then has that grindy noise sound like your still turning the key while the car is already running.
My hand is off the key when this happens. Like I said, the car has already started and is running when it'll make that grindy sound. It all happens very fast..less than a 5-7 sec span from the time of turning the key.
Car now has 90,000 miles. NEED some hints as to what is wrong BEFORE the warranty goes (in a few weeks).
Old Sep 21, 2002 | 02:12 AM
Ego's Avatar
Ego
Yeah, sounds like it's not retracting properly. Grinding, sort of high pitched and bouncing a bit, right? That will burn out the starter and can damage the teeth pretty quickly.
Old Sep 21, 2002 | 05:34 AM
Shadohh's Avatar
I agree, sound like your starter. HMA shows you how to rebuild it. And its rather simple to remove. Just take out your air box or CAI and you can access, its only held in with 2 bolts.
Its either no retracting right or its needs a simple LUBE job.
Old Sep 21, 2002 | 08:53 AM
MAXXTIB's Avatar
Better get it fixed as soon as possible before it kill's your flywheel.
Old Sep 21, 2002 | 10:47 AM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Gotta agree on that one!
Old Sep 21, 2002 | 11:59 AM
Jed118's Avatar
Vehicle: Hyundai Pony
The solenoid isn't retracting properly. Some short is keeping it open
