my tib is spitting and puttering at me , Help!
Old Oct 16, 2001 | 09:45 PM
The fuel filter is below and to the right of the brake master cylinder. It is right below the cluch fluid resivor.
I doubt your local auto parts store will have a fuel filter...but give them a shot. If not..try www.stcharlesauto.com
The PCV valve is on top of the valve cover. It is connected to the hose that runs from the valve cover to the intake manifold. Of the two hoses on the valve cover...it is the left one. The PCV valve screws into the valve cover. Your local auto parts store SHOULD have that one.
Old Oct 17, 2001 | 01:32 AM
ICE3X's Avatar
i got my replacement fuel filter at a local auto parts store
still working on finding the problem though
Old Oct 17, 2001 | 12:37 PM
ICE3X's Avatar
ok, i just replaced the sparkplug wires,
seems to be running better,
I tested the old ones, and they measured fine.
so i don't know whats up with that,
i still have a bad idle, the RPMs keep going up and down while at idle, like it almost stulls. and i still have a little hestitation.
the hestitation is at low rpm, when you first step on it, either just reving it in neutral or takeing off in 1st gear.
I'm putting the new fuel filter on tommorow,
mabey that will help
Old Oct 24, 2001 | 03:04 PM
Dani's Avatar
[QUOTE]Originally posted by ICE3X:
[QB]ok, i am not sure how to explain what is wrong, but i'll try.
for the past week now the car has been Doing this.
mainly when you step on it, it goes put..put..put..vroooom...put..put
kinda like it putters, then it starts to go, then putters again, then finnaly takes off.
in prety much every gear. like the power is not there.
Mine did the same exact thing 3 times today--first time it scared the **** out of me LoL...and i was like wtf? It wast like I was flooring the gas pedal or anything...i was gradually going faster and after about 60-the car spit at me lol...Im gonna see it still does this 2morrow...
Old Oct 25, 2001 | 02:36 AM
ICE3X's Avatar
Dani,
you should still have a warranty, right?
take it to the Dealer and have them look at it, mabey you just got some bad gas or something, Hopefully
New York, huh,
I was just up there last Saturday
I saw a 2 gen yellow tib go by in "Pond Eddy"
you know who it was?
