Cat Cams Help!!!!
Old Jan 10, 2002 | 08:04 AM
Guilty's Avatar
Vehicle: Custom Wagon
Which would be the better cam the HKS or the catcams?? The HKS has a duration of 264 and they are about the same price.
Old Jan 10, 2002 | 08:10 AM
2 UNIQ's Avatar
If you go with a 264 Duration your gain will mostly be top end.You have to ask yourself if you want low end to midrange power or midrange to high end.Also with a higher duration cam you may possibly loose some low end torque but gain in the top end.Its our choice. LET ME KNOW!!
Old Jan 10, 2002 | 10:04 AM
Red's Avatar
Red
Cheuk has mentioned on several occasions that N/A cams up to 272 have been used in Korea and found huge gains in the MIDRANGE as well as the top end.
However, cams with large duration (252 and above) need to have the head ported for the full effect. Slapping in a set of 272/272 intake/exhaust cams on a stock head may net you another 15 wheel horsepower, but having the head ported along with the cams will yield significantly better results (well into the 20's or perhaps even higher depending on other mods to your car)
-Red-
Old Jan 10, 2002 | 11:24 AM
JP's Avatar
JP
Vehicle: 1998 Accent
Yup, that's why when the dyno results are finished on my stock head, I'll swap the cam into my new head with all the trimmings. This is going to be a good spring!
Old Jan 10, 2002 | 06:18 PM
Guilty's Avatar
Does anyone know the duration specs of the catcams?
Old Jan 10, 2002 | 11:34 PM
2Uniq Said he had them. I have e-mailed him for the Dynos and specs, and I will post them up.
Old Jan 11, 2002 | 05:49 AM
2 UNIQ's Avatar
Random i emailed you the Dyno numbers and specs!!!!
Old Jan 11, 2002 | 07:54 AM
Guilty's Avatar
Can't wait to see the dyno sheets. Also will this be a good set of cams to run later on if I go turbo?
Old Jan 11, 2002 | 10:24 AM
JP's Avatar
JP
Nope! If you are going turbo, good N/A cams are not for you.
Old Jan 16, 2002 | 04:25 AM
whiteshark's Avatar
dyno and spec??? where?
