Cat Cams Help!!!!
Old Jan 8, 2002 | 08:14 AM
msilvertib's Avatar
Default Cat Cams Help!!!!
I was searching for some cams for the hyundai Tiburon 1998 FX 2.0L and found that cat cams has them!!!
Will those cams really improve performance?
Old Jan 8, 2002 | 08:40 AM
Where did you find them? What are the specification on the cams?
Old Jan 8, 2002 | 12:02 PM
2 UNIQ's Avatar
I had Cat Cams in my Tibby a while ago.
I posted this on the forum a while back.If uou do a search on the Fxtreme board you will see it there.Catcams make different stages and are made in Germany.These Cams are not a regrinnd they are BILLET!!!
I tested out the first set of cams they had last year a=in the spring and Dynoyed at about 6WHP.They were a 248 degree duration cam if im not mistaken.I cant recall the specs but they were pretty good cams.They are a bit pricey but EXCELLENT QUALITY CAMS.If anyone needs a set of these cams let me know as i can get you a set.
Old Jan 8, 2002 | 12:11 PM
JP's Avatar
JP
Vehicle: 1998 Accent
The updated version of the Beta cams have been dynoed at 15 hp increase. I have the Cat Cam for the 1.5 SOHC in my Alpha. It is going down to DPE for its next dyno run in two weeks. They are excellent quality cams, and my seat-of-the -pants dyno is impressed. I can't wait to see how the numbers support it.
To buy them go to www.jrponline.com
[ January 08, 2002: Message edited by: JP ]
Old Jan 8, 2002 | 02:47 PM
Julez's Avatar
Vehicle: 2008 Accent
So are these pretty good n/a cams then?
I'm looking for some really good n/a cams
Old Jan 9, 2002 | 01:37 AM
Are you refering to Updated Cat cams, or the 2001 Elantra Intake cam in the Tiburon?
Either way, were did you see that? I'd like to see the before and after Dyno sheets showing either test!
Old Jan 9, 2002 | 02:45 AM
msilvertib's Avatar
so they are really good quality cams!!!! But in JRP they dont show any specs not even deg, I was thinking in buying them but would they work with N2O? and if i upgraded to a supercharger would they still work?
Old Jan 9, 2002 | 10:19 AM
2 UNIQ's Avatar
Random!!
I know the owner of JRP as well as the workers there!!
I had these Cams in my car last year in Ma and Had some dyno numbers with the FIRST SET OF CAMS THEY HAD AVALIABLE!!
Now they carry a few differnt stage cams for the Tibby.
All these Dyno runs were done in Montreal,Canada on a Accent with a a stock Tibby motor as well as another dyno run with a CAI.
RANDOM,if your intrested in the Dyno numbers i can get them for you if you like.Email me if your intrested!!!! smile.gif smile.gif smile.gif
Old Jan 10, 2002 | 07:05 AM
2 UNIQ's Avatar
Random!!!!
I just got back from my friends shop with some info on the Catcams for the tiburon.I have a photo copy of the dyno runs with these cams installed.The Dyno sheets that i have show a gain of 7.2WHP and Torque should a gain of 2.6 at the wheels.
THESE CAMS ARE THE FIRST SET TAHT THEY HAVE.
They have another set of NEW Catcams which showed a gain of 14HP at the WHEELS.
He was trying to find the Dyno sheets but couldnt find them.I do remember going to his shop a month ago and seeing this 14WHP GAIN!!
I do have the Full specs for these cams on paper if your intrested RANDOM!!!
I also have the the two runs where one is stock with CAI and another run with the cams and CAI!!
Old Jan 10, 2002 | 07:11 AM
2 UNIQ's Avatar
If you guys are intrested in these Cams i can can you a set!!
We can even do a group buy on the Catcams and i can save some money.
Remember though these cams ARE NOT CHEAP.They are made in Germany and are BILLET Not a Re-grind.They specilize in making Cams for Porchse!!
You are looking anywhere from $750-$800US for a set!!
Leave your name if your intrested!!!!!
