Cars rear end wanders?
Old Jul 1, 2010 | 03:20 AM
EclipseMTL's Avatar
Default Cars rear end wanders?
When I'm driving along, ONLY when I'm going left around a curve, my rear end feels like it doesn't want to follow the rest of the car, like it almost wants to keep going straight. It only does this kinda fishtailing when I'm going left, not right, and it gets more prominent with speed. Its really quite scary, especially when another car is next to you, and you feel like you don't have control of it. I took my car in Monday to get an alignment since I put new springs and struts on, hoping it would've fixed the problem somehow, but it didn't. It also did this before the new struts and springs were put on. Also, when I had it aligned, they replaced the outer front tie rod, saying it had some play to it. What should I check to see if somethings loose that may be causing this? Or is it some weird quirk with Accents?
Old Jul 1, 2010 | 01:20 PM
Mine doesn't do anything like that.
You had them check the alignment for all 4 wheels? Not just a front end alignment right?
If it was me, I would put the rear end of the car up on jack stands and see if anything has excessive play. I would look especially carefully at the control arm bushings to be sure one isn't messed up. Also check to see if anything looks bent.
Old Jul 1, 2010 | 01:40 PM
EclipseMTL's Avatar
Yep, all four tires got checked. I'll do what you said and put her up on some stands and give everything a look over again. Thanks floyd!
Old Jul 1, 2010 | 04:12 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
I have a simular issue on right hand turns but its only occasional, back ends feels like it wanted to continue straight but its only for a fraction of a second, havnt scared myself bad enough yet to get the rear end up an look.
Old Jul 1, 2010 | 04:52 PM
Well if either of you gets it figured out be sure to post back to give others a place to start looking.
Old Jul 1, 2010 | 06:14 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
friend of mine had an accent do something like that, bad bushing on a rear multlink thing.
Old Jul 1, 2010 | 09:29 PM
HotBlue02's Avatar
well looks like im kid free this weekend so if i dont sleep the mornings away (afternoons to hot) then i just might get to looking.
Old Jul 2, 2010 | 07:18 AM
EclipseMTL's Avatar
If you do get around to it, let me know what you find. I'm stuck pulling double shifts for everyone since no one wants to work.
Old Jul 3, 2010 | 12:37 AM
HotBlue02's Avatar
Well i lifted the back end up and went in with a rubber mallet. I looked at all the bushings and there good from what i can see. I beat on all the suspension components with said mallet and nothing seemed to be loose. So its still a mystery for me.
Old Jul 3, 2010 | 05:16 PM
Get a couple hundred pounds of junk (or a few bags of cement) in the trunk, and see if it still does it.
