betls are squeaking
Old Oct 28, 2002 | 11:57 AM
turbulence's Avatar
Default betls are squeaking
ok, my belts squeak occasionally. it seems that they do it in the morning after a night of rain. my guess is that it's moisture in the air that causes them to squeak. after the car warms up (usually a few minutes), it goes away. i was thinking about getting some belt dressing, but could it be that the belts are just a little loose?
Old Oct 29, 2002 | 01:46 AM
Brendan's Avatar
check for oil, water on them, check to see how tight they are. Also see if they are worn/cracked. then put dressing ( only a bit ) on them.
Old Oct 29, 2002 | 09:15 AM
iTiburon's Avatar
I've heard both good and bad about belt dressings... to each his own.
Usually belts squeal for a reason, for the price of a new belt or two I'd say change 'em and make sure you don't over tighten them.
I see it's a 2000 but how many miles do you have?
Old Oct 29, 2002 | 11:09 AM
turbulence's Avatar
approx 32500 miles
