Stainless Steel Brake Lines GB #3 *PAY UP!!!*
Old Sep 3, 2004 | 03:42 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
Default Re: Stainless Steel Brake Lines GB #3
<div class='quotetop'>QUOTE (JalemX)</div><div class='quotemain'>Do these brake lines really make a difference, if so... how?</div>
our stock brake lines are rubber. The Rubber hose flexes slightly when the brake pedal is pushed, making the brake fluid travel slower to the piston. Switching to steel brake lines eliminates the flexing, and vastly increases your braking speed...
also rubber hoses tend to rip and crack. you won't see that on steel brake lines.
Old Sep 3, 2004 | 03:52 PM
Default Re: Grounding points
<div class='quotetop'>QUOTE (JalemX)</div><div class='quotemain'>hey bro, maybe if you could clear up a few things it might help make a few sales, mine included.
Also you said they are PVC coated, so that they <u>WONT</u> rust, right??
Any special tool needed to do the job, & do we have a DIY posted for brake lines (if not will you do one with these?)</div>
the braiding around them keeps them from flexing out....
they are coated, pretty damn nicely i must say. i dont think they will ever rust.
read my above post.
Old Sep 3, 2004 | 08:24 PM
Default Re: *Warning* - Window Switches + White board marker = BAD
It's stainless steel.
From what I know of Stainless, it doesn't rust.
Hence the name.
Also, it's covered in plastic.
You'd have to drive thru some acid to melt the plastic, then ... Hell, I have no clue.
I've got a set from the first GB. They are VERY nice.
Old Sep 4, 2004 | 06:45 AM
JalemX's Avatar
Default Re: Lean
okay put me down for probable's list man. As long as somebody does a DIY...
Old Sep 4, 2004 | 09:05 AM
Default Re: Official Bush vs. Kerry Thread
JalemX, if you also read the other linked threads that I mentioned, you'll see answers for most of your questions. They make a HUGE difference in braking.
Old Sep 4, 2004 | 09:11 AM
you have to bleed your brake lines first, then put the new lines on, then add new brake fluid? correct?
put me for a probables list.
Old Sep 4, 2004 | 10:39 AM
Default Re: Spike is working on creating fenders for the Tiburon.
Webtech has the proper bleeding procedure.
Old Sep 4, 2004 | 12:15 PM
Talux's Avatar
Default Re: Free Cam Sprocket Mod !
I'm in, will pay in 2 weeks smile.gif missed this last time, was hoping someone would redo this smile.gif
Old Sep 4, 2004 | 12:23 PM
<span style="color:cyan"><span style="font-size:36pt;line-height:100%">I NEED YOUR FULL NAMES!!!</span></span>
Old Sep 4, 2004 | 01:48 PM
Default Re: DIY - Resonator Removal
<div class='quotetop'>QUOTE (HyundaiKitCoupe)</div><div class='quotemain'>you have to bleed your brake lines first, then put the new lines on, then add new brake fluid? correct?
put me for a probables list.</div>
no, bleeding is the process of getting all the air outta the lines. when you first take off the brake line(at the caliper), be sure to have a little tupper ware container to catch the brake fluid that leaks out. then once all the brake lines are off, you put the new ones on. you then will have to fill the master cylinder with brake fluid(making sure there is plenty kept in it the whole time you bleed). then you just get all the brake fluid from the MC to the calipers by bleeding, untill there is no air left in the lines.
