This is an awesome group buy already going on at NewTiburon.com and they neglected to post it anywhere else:
http://www.newtiburon.com/forums/showthread.php?t=6267 $60 for a great mod. |
Redzman, is yours going to be starting soon? If not, I am in on this one.
Yeah, for 40 bucks it's a thicker "Phenolic Spacer", and not a gasket. Let me email that guy again and tell him I'm gonna start it.
*EDIT:* Okay, emailed the other guy on the deal, he should be back to me shortly. |
what is a phenolic spacer...and where does it go...effect on performance?
They lengthen the intake runners and increase air velocity into the head, increasing power. They also almost CANCEL the heat transfer between the block and the IM, vastly reducing the intake temperatures and increasing power. Results are usally around 5% and much more throttle responce, not to mention, drops of intake temps around 75 to 100 Degrees.
On the bad side, depending on the thickness of the spacer, you may have to put in new studs. |
Sounds good to me for 40....and man what a bad site setup they have...all that generated dash crap for each post is annoying.
Members
Yeah, I registered there just to keep the whores from phreaking my name.
It's neat at first, but confusing. |
SpeedFactor
That site is 56k ---> die!!1!!1!!
REDZ, I have been interested in the Airram IM from kspec.
w/ the phenolic spacer would the IM be pushed back enough to clear a motoria (AOS) Front strut bar?? I know there have been clearance issues w/ it. the spacer, IM and matched TB will prob be my next HP mods if so. |
Hmm...
Good question. I guess I'd have to see where the IM and the Strut bar are in relation to eachother first. The Motoria SB should fit over the Airram IM. |
