Gentex Rear-View Mirrors
Old Sep 30, 2004 | 05:31 PM
Default Re: Unofficial RDTib Females Thread *pics*
Awesome find man. Really.
I'm getting one. It'll be a bit, but I'm getting one.
Old Sep 30, 2004 | 05:33 PM
JalemX's Avatar
w0rd. Me 2. This deal going to stay for a while? (few mo.?)
Old Sep 30, 2004 | 06:59 PM
Default Re: Results from tonight's race :)
<div class='quotetop'>QUOTE (tibby01)</div><div class='quotemain'>redz, this will prolly be going on for a while. there really isnt an end date.</div>
Old Sep 30, 2004 | 07:01 PM
BlackTibby00's Avatar
Nice..............time to save up some more money.
Old Oct 2, 2004 | 05:24 PM
heres a DIY i found on exd.com for installing these mirrors.
http://www.elantraxd.com/forums/showthread...ighlight=gentex
Old Oct 3, 2004 | 08:34 AM
CyberShark's Avatar
Default Re: FS:Custom Subwoofer Enclosure
That will definatley be a nice interior upgrade..just a matter of saving up some dough.
Old Oct 3, 2004 | 11:25 AM
Vulcanwolf's Avatar
Default Re: 1.8 cam in but now running sluggish
i might be in on this too. Maybe in a little. Where would a good place for the air sensor be?
Old Oct 6, 2004 | 06:34 AM
Default Re: New England chapter
I have a BMWz4 auto dim mirror in my Tib... here was how I mounted it... yours might be a different.
If you take the stock mirror off of the mount on the windsheild and look hard at it.. you will find the "Shoe" or the part of the mirror that mates with the mount is actually detachable from the mirror itself. I took this round piece of metal and because the Z4's mirror uses a similarly removeable shoe, drilled it to take the screw mounts my new mirror uses.. Once it was screwed together, it mated up to the windsheild perfectly. It almost looks stock.
If the autodim is like mine, it does not autmatically go dark at night, but uses two sensors.. one facing the front of the car and one facing the rear,,, when the one facing the rear senses that it is dark out, the mirror looks to the rear facing sensor for light hitting it.. like from a car behind you. When this (more) sensitive sensor detects light and the front sensor detects darkness.. the LCDs in the mirror glass go dark
Old Oct 6, 2004 | 05:00 PM
Default Re: FS: aftermarket steering wheel
<div class='quotetop'>QUOTE (Vulcanwolf)</div><div class='quotemain'>i might be in on this too. Maybe in a little. Where would a good place for the air sensor be?</div>
Well, I'd say wherever you want a temp reading. Your trunk, wherever.
Old Oct 8, 2004 | 06:24 AM
Default Re: Rally Crashes
Having driven a truck with a tempeture package like like.. I suggest somewhere under the car away from the engine, exhaust, or radiator. Also, make sure it is not attached to any body part that is directly affected by the sun... Your best bet is probably in the driver's side fender where a lot of people route the CAI to.. it is in the shade, you can mount it to the underside of the car where it is not affected by solar heat, and far enough away from the engine you should not have that being a problem.
HOWEVER! Do not mount it to the underside of the bumper close to the ground, the tempeture of the road will elevate the readings.... at or just below headlight level would be best.
