Beta 1 Airram Intake Manifold GB! *CLOSED*
Old Jul 20, 2004 | 11:56 AM
  #191
Shouldn't be mang. Mine is upright.
You happy?
Old Jul 20, 2004 | 11:57 AM
  #192
UltraTibby's Avatar
Dont feel bad 01roller mine will be upside down also...... They put the logo on the bottom of the BBTB.
Old Jul 20, 2004 | 11:58 AM
  #193
Just make sure you 2 put the BBTB spacer in the right direction if you use the smaller one. Put the beveled edge towards the MAF.
Old Jul 20, 2004 | 12:04 PM
  #194
UltraTibby's Avatar
Excuse me for being dumb, but the spacer, is that the thing that looks like a gasket?
Old Jul 20, 2004 | 12:10 PM
  #195
No, that's a gasket. I meant the rings.
Old Jul 20, 2004 | 12:18 PM
  #196
UltraTibby's Avatar
So basicly if you are planning on using it at 61mm then you dont have to screw with the spacer then. You only need to if you want to bump it down to the 59mm. Right?
Old Jul 20, 2004 | 01:00 PM
  #197
No, there should be 2 rings, if there aren't 2, then the 60 is already installed.
Old Jul 20, 2004 | 03:04 PM
  #198
01roller's Avatar
so since ive got only 1 ring that means my opening is at 61mm and with the ring it would be 59mm and the ring goes in the opening nearer the intake tube ....
Old Jul 20, 2004 | 03:16 PM
  #199
Default Re: Type R Wing Group Buy *2 Spots Available*
The BBTB came ON the IM?
It depends on the ring currently in your BBTB mang. The one sitting there on the carpet, is it beveled on one edge?
Old Jul 20, 2004 | 03:21 PM
  #200
01roller's Avatar
no the bbtb didnt come on the manifold i put it on there to keep them together and yea... the ring is beveled on the inside on one side
