Is it Safe to Run a Oil Lubed Electric Air Compressor in Winter Conditions?
Old Oct 27, 2011 | 02:31 PM
kromez's Avatar
Vehicle: 2002 Elantra
Default Is it Safe to Run a Oil Lubed Electric Air Compressor in Winter Conditions?
Just wondering if this will rust the internals - sucking in cold air from outside into the machine. Or should I situate the unit inside and run mega length hoses?
Old Oct 27, 2011 | 09:32 PM
Worry more about draining the tank than rusting the compressor under normal operating conditions.
Old Oct 28, 2011 | 01:41 PM
zero_gravity's Avatar
Vehicle: 2004 Hyundai Accent
check the manual for the compressor (if available). in extreme cold i'd be concerned about the oil viscosity.
