ohhhh ****????
Old Dec 13, 2001 | 04:09 PM
Mister694's Avatar
Default ohhhh ****????
ok if you look at the short shifter on sharkracings site.... is that bottom piece supposed to come with the shifter??? or what is it??? how do i go about getting one if it is necessary for a short shifter??? it is from mhp....please help me
Old Dec 13, 2001 | 06:46 PM
Xorro's Avatar
Vehicle: Mitsubishi Lancer Ralliart GSR
I don't know about the MHP short shifter, but the Shark Racing one has two parts. If you look at http://www.speedstate.com/Hyundai_Section/...ort_shift2.html in the first pic, both parts which are labeled 'unclip' are the two parts of the short shifter, one controls the forward/back movement, and the other piece has the gear knob attached.
Hope that made some kind of sense
Old Dec 14, 2001 | 01:52 AM
Reid's Avatar
If memory serves, the MHP unit only shortens the length of the shaft...it doesn't have the two pieces that the SR unit has.
Old Dec 14, 2001 | 02:14 AM
iTiburon's Avatar
Reid is right-on!
I have the MHP and it only replaces the long (fore and aft) shifter. It doesn't change the left - right movement at all.
Old Dec 16, 2001 | 12:29 AM
DPHC's Avatar
If it doesn't change the left - right movement at all won't the shifter hit it when you shift gears? I have a SR short shift and its what the car needed from the get go. If you don't have this I HIGHLY recommend it. wink.gif
Old Dec 16, 2001 | 05:44 AM
Decker's Avatar
I have the short shifter, and I was pissed that it didn't come with the second part. But I can tell a huge difference, and you don't have to move the stick left or right when shifting. Basically it's pull down, push up, pull down and your in fourth already. It works beautifully. No side movement required. Only from fourth to fifth you need a little movement to the right.
Not worth changing.
