Msd dis 2 or 4
Old Oct 29, 2015 | 11:34 PM
patuner11's Avatar
Vehicle: 2000 hyundai tiburon airram zex direct port nitrous outlet standalone fuel cell obx light weight pulleys obx crank pulley fidanaz cam gear 1.8 set up msd dis 4 fidanza flywheel act 6puck non sprung clutch lowering springs m/t drag radials much more much more to come
Default Msd dis 2 or 4
Im looking into an msd dis 2 but can I use an msd dis 4? because I already have a 4. Does anyone know how to hook them up I need some help with that
Old Oct 30, 2015 | 06:13 AM
JonGTR's Avatar
Use the 4.
/thread
Old Oct 30, 2015 | 11:10 AM
patuner11's Avatar
Originally Posted by JonGTR
Use the 4.
/thread
JonGtr YOU wouldn't happen to know how to hook it up do you I need help on that like what wires go where
Old Oct 30, 2015 | 11:50 AM
JonGTR's Avatar
Did you read the MSD wiring diagram?
Same wiring for the cop, but using only 2 factory coils.
Old Oct 30, 2015 | 01:45 PM
patuner11's Avatar
I didn't have one I bought it from someone but this will help a lot
Old Nov 3, 2015 | 10:50 AM
patuner11's Avatar
mines is a dis 4 not a dis4 plus will this diagram still work for me I just got it in the mail
Old Nov 3, 2015 | 11:05 AM
patuner11's Avatar
joe cars 045.png I did find this
Old Nov 3, 2015 | 12:31 PM
JonGTR's Avatar
They both wire the same! And yes, that person explained it exactly the way I did the wiring. Like I said, read MSD's instructions. They're clear and easy to follow.
Old Nov 3, 2015 | 05:34 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Hmmmm... I wonder who wrote that?
Old Nov 4, 2015 | 01:30 AM
patuner11's Avatar
What Im confused about is i have a 3 wire plug into the coil blue looks like red and black which one is the coil positive and which ones are the coil negative channel 1 and 2?? Does triggers 1 and 2 and 12v go into the coil harness? which is the bigger wires that go into the coil plug correct? Does anyone know which wires are trigger 1 and 2 and 12v in the wire harness?? I also read on msd that triggers 3 and 4 need to be grounded when not in use is this right.. Or am I misunderstanding all of this? Thanks for the help much appreciated
