Msd dis 2 or 4
Im looking into an msd dis 2 but can I use an msd dis 4? because I already have a 4. Does anyone know how to hook them up I need some help with that
Use the 4.
/thread |
Originally Posted by JonGTR
(Post 707752)
Use the 4.
/thread |
Did you read the MSD wiring diagram?
Same wiring for the cop, but using only 2 factory coils. https://img.photobucket.com/albums/v...psszuj5gcq.jpg |
I didn't have one I bought it from someone but this will help a lot
(Post 707757)
1 Attachment(s)
Attachment 2113 I did find this
They both wire the same! And yes, that person explained it exactly the way I did the wiring. Like I said, read MSD's instructions. They're clear and easy to follow.
1 Attachment(s)
Originally Posted by i8acobra
(Post 707821)
What Im confused about is i have a 3 wire plug into the coil blue looks like red and black which one is the coil positive and which ones are the coil negative channel 1 and 2?? Does triggers 1 and 2 and 12v go into the coil harness? which is the bigger wires that go into the coil plug correct? Does anyone know which wires are trigger 1 and 2 and 12v in the wire harness?? I also read on msd that triggers 3 and 4 need to be grounded when not in use is this right.. Or am I misunderstanding all of this? Thanks for the help much appreciated |
