Lucky to be alive, will i be ok ?
Old Aug 3, 2012 | 09:50 AM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default Lucky to be alive, will i be ok ?
i was welding my exhuast up for my hyundai accent beta turbo and i tripped over..
I went the case in on my welder and the case touched the coil inside. THe welder shocked me and burned my side 0.5-1 sec passed and it stoped...
The welder is wired into a uk coooker mains (240V @ 45 Amps) i blowed the 45amp.
Iv been dizzy and sick since its happened and im really tired.
Should o be ok to sleep it off?
Old Aug 3, 2012 | 10:22 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Thats alot of juice, you may want to contact medical professionals on this rather then Hyundai Fan Boys. Hope things go well for you buddy!
Old Aug 3, 2012 | 10:43 AM
OTECTom's Avatar
I WOULD SUGGEST AGAINST SLEEPING IT OFF AND DIAL 999
Old Aug 3, 2012 | 01:05 PM
Antonyr123's Avatar
cant sleep and dial 99 lol.
Yes im not that big on shocking myself but i didnt know if any guys here had anything happen to them and if how i was feeling was normal.
Thanks anyways. and cheers hot blue.
Old Aug 3, 2012 | 02:41 PM
wheel_of_steel's Avatar
Holy crapamoli. I hope your heart is a strong one.
Old Aug 3, 2012 | 05:16 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
So....... any update? Are you still alive?
Old Aug 4, 2012 | 07:05 AM
Antonyr123's Avatar
yea im still kicking. im 6ft 8 and 19 Stone. so my size may of helped me. Thanks for all the support
Old Aug 5, 2012 | 07:46 AM
If your heart didn't stop permanently and you don't have grievous burns you'll most likely be okay.
Getting electrocuted sucks, but it happens to people pretty regularly. I know people that like zapping their buddies with a welder for entertainment.
Old Aug 5, 2012 | 01:55 PM
Welders are usually lower voltage. Burn the skin maybe, but not AS likely to jump across 2 meters of flesh as 240v. You COULD have done minor damage to your heart and a scan at hospital would probably show it up. If you're like most of us, you probably won't go even if you should, seeing you're still alive for now.
Old Aug 5, 2012 | 03:59 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Dont wnt to be a dick, but its not the voltage that kills you its amperage. I am an Avionics Technichan and took a few good qualitu shocks, one gave me an irreglar heart beat and I felt alot like you described. That was my worst at 1250 vdc and popped the 15amp fuse and I was holding the component in both ands so it went right through my chest.... But im hete and fine now, you should be okay, but get and Ekg! Irregular heart beat can kill you in your sleep!
