WRC3"Replica"
WRC3"Replica"
Hello everyone,
I would like to turn my 2002 Accent into a WRC3 "Replica", as anybody here done anything like that??
[ January 22, 2003, 05:17 AM: Message edited by: canopyflier ]
Just buy LOTS of stickers, get a fake roof scoop, throw on about 10 giant fog lights on the front, and you're good to go....
you guys also forgot the
DOHC four cylinder 2.0L(1998cc) 16v Beta,
Garrett turbocharger w/34mm restrictor,
9.2:1 Compression,
300 bhp
383 lb-ft,
6-speed sequential gearbox,
triple plate pull-type carbon clutch,
304mm brake rotors (front and rear),
18'x8" OZ wheels. you should also weight reduct your car to a 2700 total weight. eek!
9.2:1 Compression,
300 bhp
383 lb-ft,
yet you were right its is a 6spd
Full time four wheel drive. The front and center differentials are electronically controlled. Mechanical, self-locking rear differential. 50%-50% F-R torque distribution.
Six speed X-Trac non synchronized, sequential shift gear box longitudinally mounted. Carbon triple plate clutch, Ø140mm.
High ratio rack and pinion, power assisted steering.
electronic cabin adjustable antiroll bar.
^^ I WANT !!
8"x18" wheels, Michelin 20x65/18
Chassis is Monocoque, steel construction.
Cast aluminum block and head construction, front transversally mounted.
1998 cm3 , water cooled turbo charged. Bore: 84mm, stroke: 90mm. Compression ratio 9.2:1 2 OHC belt driven and hydraulic tappets. 4 valves per cylinder. Engine oil cooler.
Engine output: 300Bhp @ 5300rpm. Engine torque: 520Nm @ 3500rpm. Garrett/Allied Signal TR30R turbo charger and Hyundai/Pectel engine management.
yes it does weigh 2700 pounds, WOW
^^ I WANT !!
