WRC3"Replica"
Hello everyone,
I would like to turn my 2002 Accent into a WRC3 "Replica", as anybody here done anything like that?? [ January 22, 2003, 05:17 AM: Message edited by: canopyflier ] |
Just buy LOTS of stickers, get a fake roof scoop, throw on about 10 giant fog lights on the front, and you're good to go....
rolleyes.gif |
and strip the interior, and make yourself a wide bodykit.
dont forget awd/turbo |
you guys also forgot the
DOHC four cylinder 2.0L(1998cc) 16v Beta, Garrett turbocharger w/34mm restrictor, 9.2:1 Compression, 300 bhp 383 lb-ft, 6-speed sequential gearbox, triple plate pull-type carbon clutch, 304mm brake rotors (front and rear), 18'x8" OZ wheels. you should also weight reduct your car to a 2700 total weight. :D eek! |
The 2003 Accent is a totally different body style than the 2002.
yet you were right its is a 6spd
Full time four wheel drive. The front and center differentials are electronically controlled. Mechanical, self-locking rear differential. 50%-50% F-R torque distribution. Six speed X-Trac non synchronized, sequential shift gear box longitudinally mounted. Carbon triple plate clutch, Ø140mm. High ratio rack and pinion, power assisted steering. electronic cabin adjustable antiroll bar. ^^ I WANT !! 8"x18" wheels, Michelin 20x65/18 Chassis is Monocoque, steel construction. Cast aluminum block and head construction, front transversally mounted. 1998 cm3 , water cooled turbo charged. Bore: 84mm, stroke: 90mm. Compression ratio 9.2:1 2 OHC belt driven and hydraulic tappets. 4 valves per cylinder. Engine oil cooler. Engine output: 300Bhp @ 5300rpm. Engine torque: 520Nm @ 3500rpm. Garrett/Allied Signal TR30R turbo charger and Hyundai/Pectel engine management. yes it does weigh 2700 pounds, WOW |
