under car neon
i have street glow neons the street glow kit comes with mounts that install tight up agenst the car, un like the light glow that hang, i put my rear neon up on the frame of the back, same with the front but on the front not on the back [lol] the sides i just screwd right up in to the car i have had them for 4 years and never came off you have a body kit you should not have a problem with bulb exposure at all
i will TRY to get some pics for you. good luck
i actually do have some pics. havent figured out where to put the rear one yet. im prolly going to make a bracket.
just checked, and the pictures somehow turned out really bad. anyway, for the sides i mounted it right nest to the big beams, obviously on the side facing outwards. for the front, i connected it to that little plastic peice that hangs down.
sorry its not more detailed.
Couple questions about exterior mods
yea.... i've got the new streetglow LED neon underbody kit. i mounted mine with two zip ties on the front bumper... just drilled two holes on both ends of the bumper and ran the zip tie through and secured around the neon bar. on the sides i just mounted it right beside that lip that is on the sides of our cars... very good hiding place. the back i mounted to the rear bumpber via its metal retaining bar... ill have to take some pics to better explain this... but the way it is mounted you can really see the lights at night... just check out the pic under my name
www.newlevelmotorsports.com
just get a quality kit dude.... dont piece one together. most kits come with two 36 and two 48
