i just what to know of thos of you how have under car neon or LED how and where did you mount it.and if you have pics that would be great.
i have street glow neons the street glow kit comes with mounts that install tight up agenst the car, un like the light glow that hang, i put my rear neon up on the frame of the back, same with the front but on the front not on the back [lol] the sides i just screwd right up in to the car i have had them for 4 years and never came off you have a body kit you should not have a problem with bulb exposure at all
i will TRY to get some pics for you. good luck |
yeah i put mine in 2 weeks ago, i just mounted it where it fit, but that front was a little harder, but mine worked great..
ok thxs and how long are yours mine are 36 and 48"
i actually do have some pics. havent figured out where to put the rear one yet. im prolly going to make a bracket.
just checked, and the pictures somehow turned out really bad. anyway, for the sides i mounted it right nest to the big beams, obviously on the side facing outwards. for the front, i connected it to that little plastic peice that hangs down. sorry its not more detailed. |
Mine are eurolites. They work very nice.
ok i tried to put them in and its tough thrying to get through the stuff under my car so im goin wait till moring to try drilling it
Couple questions about exterior mods
yea.... i've got the new streetglow LED neon underbody kit. i mounted mine with two zip ties on the front bumper... just drilled two holes on both ends of the bumper and ran the zip tie through and secured around the neon bar. on the sides i just mounted it right beside that lip that is on the sides of our cars... very good hiding place. the back i mounted to the rear bumpber via its metal retaining bar... ill have to take some pics to better explain this... but the way it is mounted you can really see the lights at night... just check out the pic under my name
where is a cheap place to get them? and how long of tubes/how many do you need, i see some kits come with 24, 36, and 48..
www.newlevelmotorsports.com
just get a quality kit dude.... dont piece one together. most kits come with two 36 and two 48 |
