removing emblems?
Old Oct 18, 2003 | 12:08 PM
canadianshark74's Avatar
True, newer paints do not fade like the older finishes, but they do fade, if you have a black car, you will know this. Just use some rubbing compound or a scratch remover, that should blend it. If you have a silver car you probably wont even see the fade.
Old Oct 18, 2003 | 04:44 PM
Red is another BIG offender of paint fade... Becareful with the polish though.. that is a clear coated surface you are working with.
Old Oct 23, 2003 | 03:39 PM
NightShark's Avatar
yeea paint fading is a bad issue..
Old Oct 24, 2003 | 01:17 PM
RedShark's Avatar
i removed the stock tiburon emblem and replaced it with kdm spec emblems, but i have the "h" on there still. alot of people have told me that it would look good to take off the "h" and leave on just "turbulence" but it looks like it's indented beneath the emblem. if i removed the "h" would it be just like when i removed the stock tiburon...flat and smooth or would it have a groove in there?
Old Oct 24, 2003 | 03:00 PM
KayJai's Avatar
There'll be a indent and 2 holes
