RD2 to RD1 front clip swap
Old Apr 24, 2011 | 07:21 PM
CBowley603's Avatar
Vehicle: 2001 Tiburon
Default RD2 to RD1 front clip swap
So I was wondering if this has ever been done. I think the RD2 is probably (to me) one of the ugliest creations man has ever made. So I was thinking if the car is basically the same, would it be possible to swap the hood, fenders, bumper-cover and headlights between an RD2 and an RD1?
Old Apr 25, 2011 | 10:50 AM
I'm going from memory..and I'm old, so my memory may be spotty/wrong.
The RD2 Tib has a different top radiator support/hood latch (due to the shorter hood). So it's not just as easy as swapping the fenders/hood/lights/front bumper. You need to replace that top radiator support and hood latch assembly from the RD1. That top radiator support is spot welded in, so you would need to drill out the spot welds on both, then literally bolt them together on the final car (or shear the spot welds and then re weld).
I seem to remember there are some other minor thing that make the swap a PITA, but the details escape me @ the moment (like I said, I'm old and memory is going).
I do know that it's "doable"..it has been done in Korea. They had many RD2 tibs with RD1 front fender/hoods.
Old Apr 25, 2011 | 10:52 AM
x2 on Random. Upper radiator supports, fenders, headlights, hood, turn signals. That sounds about right.
Old Apr 25, 2011 | 11:10 AM
turbosocks's Avatar
hardest part will be the radiator support assembly, which CAN be done with rivets (and has been) but the rest will be pretty much swap in and go..
Old Apr 25, 2011 | 04:08 PM
CBowley603's Avatar
Cool thanks for the info.
Old Apr 25, 2011 | 05:06 PM
ChattTownShark's Avatar
Vehicle: 2001 tibby
correct me if im wrong but i think the fenders are the same... the headlights need to be change and rd1's are 9007 and rd2 are h7. top radiator mount and front clip if i remember is all thats needed... then foglights if you have that option
Old Apr 26, 2011 | 10:05 AM
turbosocks's Avatar
for the headlights, you could just get a H7 to 9007 HID kit and your good to go.
Old May 2, 2011 | 11:00 AM
FlyRyde's Avatar
Can you believe we're still doing this stuff? I'm dying to find a crazy cheap shell of an RD2, do the swap to the front, and then go on a hunt for a wrecked Genesis to frankentib up another project
Old May 2, 2011 | 12:37 PM
If you want to pay for it, you can build yourself a deuce coupe with all steel aftermarket-sourced parts. Don't be surprised at an unusual car that's only a decade old still having enthusiasts, mang!
Old May 3, 2011 | 12:19 AM
wheel_of_steel's Avatar
galatea tib is always relevant.
