Questions, Questions
Old Dec 2, 2006 | 07:48 AM
artistsds's Avatar
Eh, feels like I'm asking so many questions these days...
So last night after removing my driver's side headlight assembly and removing resonator B and finding that my friend wasn't going to let me use his oven to separate the lenses, I replace the headlights only to find that while my cornering light does indeed signal, it doesn't function as parking lights. So, to shorten that incredibly run-on sentence, I have high level but no low level in my left turn signal, front end. I made extra sure not to bump or touch the bulb when I took it out. The connections were tight and clean. WTF.
Also, any tricks for putting the corners back in? I got mine in but the fit isn't quite what I'd like. It's not flush on the front side, but I really can't push it back in any farther. I used a little bit of force with no result.
And lastly... where's the best place to find weather stripping for around the windshield and such?
And yes, I did search the forums but didn't really find either definitive or round-about answers.
Old Dec 2, 2006 | 10:27 AM
You probably have the wrong bulbs in your corners. Double check using the FAQ as guide to see if you have the right ones.
For the weatherstripping, what's the problem?
If it's coming off, the dealer or any glass shop can fix it for you.
Old Dec 2, 2006 | 10:55 AM
rusomen's Avatar
there is 2 connections on the bulb if you swap them or put it other way bulb is not gonna work properly so try to reconnect the bulb other way
artistsds's Avatar
They're the right bulbs; they're the same ones that came with the car. I wasn't changing anything over, I just took out the housings because I mistakenly though my friend wouldn't be a @#$% and let me use his oven to do clear corners and also black the headlight bezels. The bulbs worked at both levels prior to me taking out the assembly, now they're only functioning as indicators and not as parking lights.
Old Dec 2, 2006 | 11:10 AM
Change the bulbs?
You probably broke a filiment.
