Orange peel
Vehicle: 2006 Tiburon GT
Im starting my hand at learning how to paint and a couple of small things I have sprayed came out with a lot of orange peel. I know it can be wet sanded out when its dry but I have heard that one tip to lessen your chances of having orange peel is to try and dial in the gun more (increase the pressure a notch) before spraying. Anybody know if that will work before trying again?
still around just don't post much unless I can help out.This may help. For base I use my sata with a 1.3 tip at 35psi. For clear I use my devilbiss with a 1.8 tip at 25psi. I hold the gun 6 to 8 inches from the panel with a 50% overlap. I've painted hundreds of vehicles this way. Also make sure you are using the correct reducer for the temperature of your booth/garage or it will mess with you flash times.
