Left Turn Signal Problems
Old Feb 28, 2007 | 06:32 PM
J3R0MY's Avatar
ok, something is up with my fuses.
ok i fixed all my other problems with my fuses. now its doing this.
when i put my left turn signal on, the front doesn't work and the rear goes crazy fast. I checked all the fuses and they all work fine. any suggestions?
need help now ppl!!!!!! help!!!!!! ahhhhhh
Old Feb 28, 2007 | 10:00 PM
have you replaced the bulbs at all? It's common if one bulb is dead or if one of the two filaments in the rear tail light bulb is dead.
Front turn signal bulb - should have 2 filaments inside
Rear brake light bulb - should have 2 filaments inside
rear turn signal bulb - should have 1 filament inside (I believe)
Old Feb 28, 2007 | 10:03 PM
Tibbychick's Avatar
yeah that happens when theres a problem with a bulb sometimes. Did you put the wrong bulb in maybe? Or like magik said maybe its dead? When I put an LED bulb in it made the lights flash fast. Try taking em out and putting em back in, maybe that will do it. lol
Old Mar 3, 2007 | 05:55 PM
J3R0MY's Avatar
it worked itself out fine, fuse boxes are just fussy sometimes
Old Mar 3, 2007 | 11:56 PM
That's wierd... i'd expect problems in the future. I'm 100% sure the problem was the bulb. Get a new one.
