Filler question
Old Mar 9, 2010 | 09:09 AM
blue2000's Avatar
Vehicle: 2K Tib
Default Filler question
I have body filler on the hatch (shaved the hyundai emblem and filled in the section) and the filler got wet. Do i need to grind off all the filler and start over? Any input is appreciated. Thanks
Old Mar 9, 2010 | 09:12 AM
I would....body filler is like a sponge and will absorb moisture....metal is underneath the filler (unless you sprayed epoxy first, which I doubt)....moisture + metal = what????
Old Mar 9, 2010 | 09:16 AM
JonGTR's Avatar
QUOTE (Visionz @ Mar 9 2010, 10:12 AM)
I would....body filler is like a sponge and will absorb moisture....metal is underneath the filler (unless you sprayed epoxy first, which I doubt)....moisture + metal + Oxygen = what????
Old Mar 9, 2010 | 09:40 AM
I don't like using a slug of Bondo that thick anyways. It never dries within a reasonable time for me and always seems to shrink some over time.
