Ye Or Ne:how To Raise The Rev Limiter.
Vehicle: 2000 Hyundai Elantra
I've been toying around with the idea of using my DIS-II to raise my rev limiter to get some much needed power from my new turbo. I know some people have sent them away, but is there a way to specifically bypass the rev limiter all together and allow the MSD unit to control the limit. I'm only going to 7,250, but would like the ability to go higher to test some various components.
Thanks,
Sean
Thanks,
Sean
There should be. I know you can set it on the DIS2 but Im not sure how you would cut it off from the stock ecu. Redz, with your cams you should be able to go a bit higher I would think. Try it out.
