Transmission Question
Old Jun 26, 2009 | 07:09 PM
my_tib's Avatar
Vehicle: 99 hyundai tiburon
I'm currently doing a transmission swap (auto to manual) in my 99 Tiburon wondering if our cars have pilot bearing that goes between the crank and the flywheel?
thanks for your help.
Old Jun 26, 2009 | 08:33 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
They do not.
Old Jun 27, 2009 | 06:00 AM
UrS0NvS's Avatar
depending on where you got your manual trans from there is a difference in crank size. 35mm and 41mm are the two differences and you may have a flywheel that is too big for your car. i found this out personally also so i know what you are going through.
basically take a pair of calipers or a 1"-2" micrometer and measure to the shaft to see what size you have.
Old Jun 27, 2009 | 08:15 AM
Check my transmission swap thread for details on the crank nose dimensional difference
Old Jun 28, 2009 | 10:09 AM
my_tib's Avatar
Thanks for all the help guysÂÂ*.
I just measure my crank and its a 41mm crank and the flywheel i got from fidanza is 35 mm. So i looks like its going back.
