stock airbox
Old Jul 15, 2002 | 10:26 AM
2000_Tibby's Avatar
Default stock airbox
I know that there are 2 sensors and 2 tubes that are attached to the stock intake, and i was wondering if the sensor on the airbox could simply be removed? I was wondering this because i want to get a K&N cone filter and just take that off, but i don't want to hurt anything.
Old Jul 15, 2002 | 01:42 PM
Josh's Avatar
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
You will need to plug that intake air temp sensor somewhere in the intake stream if you want things to work properly.
I cut a hole in the back of my cone filter that is attached to the MAF and plugged it in there.
Good Luck
Old Jul 16, 2002 | 05:43 AM
tibboy316's Avatar
i was wounderign the same thing
i took from the rubber boot thing forward off and put a acp intmidator cone filter on there
and left the front sensor off.... does this hurt anything im sure it does because its there but anything major
Old Jul 16, 2002 | 06:22 AM
KayJai's Avatar
Well it'll be reading the WRONG Intake Air Temp.
Making it read hotter than it actually is, cuz it's reading what's in the engine bay and not inside the intake.
BTW, it's a 3/4* hole you have to drill and the OEM rubber grommet will fit perfectly.
