S-AFC EXPERTS RED CHEUK!!
Old Jun 26, 2002 | 08:36 AM
Shadohh's Avatar
2uniq, pay me$300 and a plane ticket, and I will come up and fix all your problesm tongue.gif
Old Jun 26, 2002 | 10:03 AM
2 UNIQ's Avatar
JAWS!!
When i unplug the S-AFC it reads RICH the whole time as well as i have a hard time to start the car because its SO RICH!!
But when i got it started i took it for a run and it reads RICH the whole time!!!!
Shadohh!!
You should come down and be my MACHANIC
Old Jun 26, 2002 | 11:37 AM
Shadohh's Avatar
40/h on call mechanic.
plus $1k moving expensive.
also I should charge for soon er or later becoming a canadian. but I hear the healthg plan is good smile.gif
how about a plane ticket and $300
Old Jun 26, 2002 | 11:45 AM
skierd's Avatar
Vehicle: 1997 accent L
Shouldnt this be the part where Red comes in and tells you he told you so about using the s-afc to tune a turbo car? rolleyes.gif
Old Jun 27, 2002 | 08:47 AM
2 UNIQ's Avatar
I set my High MAps to ZERO ALL ACROSS and left the low maps to -40% all across and decided to go for a run.My car still ran LEAN as it was REVING UP and not moving so i LET off the gas pedal quickly.About a minute later i get a Flashing CEL and figured it was the same problem as last week and i was right?
I had a misfire in Cylinder #1 and #4.
I changed my plugs last week and this got rid of the misfire problem.Now since i was RUNNING lean can this cause the car to MISFIRE?
Or is my misfiring causing it to lean out at WOT?
Old Jun 27, 2002 | 01:58 PM
Denisst99's Avatar
usually a misfire will cause unburned fuel so the O2 sensor will read richer
if the car is way too lean it will act almost like a misfire
Denis
Old Jun 27, 2002 | 04:55 PM
Shadohh's Avatar
ITS ****ING MISFIRING BECAUSE YOU LEANING OUT !!
You are running 10psi on BOOST
on 440cc with the stock FUEL injector pulse.
DOnt change it to 0 specially on the hig map for WOT.
god damnit
set it to +50 richen the thing UP! take a day off of work and limp your ass to the dyno under full richness !!
GET TO A DYNO
I dont wanna here you complain about your turbo one more time till you tune the safc ON A DYNO
with a wide band o2 sensor!!
