A refrigerated Intercooler?
Old Sep 2, 2001 | 06:53 PM
Default A refrigerated Intercooler?
http://www.coolflow.com/prod1.htm
Old Sep 2, 2001 | 11:16 PM
2K3GT/2K Wagon's Avatar
Very interesting.
Old Sep 4, 2001 | 03:55 AM
Iago's Avatar
Is this thing running separately from your A/C? It says that your car will cut A/C at 75% throttle, or that you should cut it manually. But by turning your A/C off, aren't you also turning off the cooling effect of this item?
Or am I missing something?
Old Sep 4, 2001 | 08:54 PM
They use a coolant "resovior" (call it a gallon, although I couldn't see where they specifiy how much).
So they basically have a tank of cold water waiting to go through the intercooler. The whole time you are driving normally, it should cool that coolant down...and only when you go to 75% or higher throttle will the AC condensor shut down. That extra coolant in the resovior works to cool the Intercooler when you shut off the AC or go above 75% throttle.
It has it's potential...but for the prices they charge, you could develop one kick ass seperate air/water intercooler.
